Metal 3D printing
Use tattoo removal laser to bind metal powder
The goal of this project is to develop a 3D printer able to bind metal powder using the Nd:YAG laser embeded in tattoo remocal machine for less than 1500$
I've first seen the [StyroPyro] video about a Nd:YAG laser embded in tattoo removal machine. then I felt on this article. This gave me the idea to build this machine
1) Order the laser
2) I need to modify the moving mechanism of the FLsun cube because im not really happy with it. I will check my new design with a conventional hotend and see if it can move nicely.
3) test the laser on metal powder, order some optics for it if needed to refocus the beam
4) Redesign the head mouting part to hold the ND:YAG laser on the 3D printer frame
5) Design a powder dispensing and containing mechanism (powder are a pain to deal with)
6) make a slicer fitted for metal binding (a few article describe moving pattern to limit warping, thermal stress, etc)
7) Experiment with audio transducer as a way to compact the powder and increase print density
8) Maye it will work
  • lacking funding and time :/
    Nathann • 06/15/2022 at 19:07 • 0 comments
    for now I am lacking the 600 $ needed to buy the ND:Yag laser.
    in a few more years that might change and i might finally have enought o afford one and have to time for myself to try it
View project log
aifirm.llc wrote 01/08/2021 at 15:21 • point
You're absolutely right. Titanium printing lasers are at 1070nm. Very close to what this machine was giving off. Each material will take a different nm.
Adding black will work.  I thought sla printer immediately when I saw this on styro piro. There is an arduino open source sla project.
You will need argon for allow type metals like Ti and aluminum.
Be overly carefull with this!
Metal Powder can ignight into a fire you wont be able to put out.  You will need argon. Look up how not to burn your house down first! Ti and mg powder is no joke.
I suggest you look into titomic. Cold spray deposition as well!
Dan Maloney wrote 01/08/2020 at 16:51 • point
If I recall correctly, StyroPyro was able to point the laser right at his skin with minimal effect because it's designed to only couple with darker pigments. I wonder if that will mean you have to stick to darker metal powders, or perhaps have to somehow tint the powders to get them to heat up enough to stick.
Just a thought, looking forward to seeing progress. Keep us posted.
Nathann wrote 01/10/2020 at 12:17 • point
Yes. I believe this have to do with the lenght of the pulse. On flickr [Andrew Harmon] seems to have manager to wed metal with longer pulse. So I will follow that road, remove the Q switch and lower the capacitor voltage or the capacity to see if it help
