Here's the bill of materials for both the BSTRD Tube Pre and the Power Supply.
It contains part numbers from Mouser, and other sources where Mouser can't provide the parts. It's recommended that you buy more than the specified component quantities, especially for cheaper parts like resistors.
These are just suggestions, there are a lot of cheaper, more expensive, better, worse and higher or lower quality components available. There are also a lot of other places to get components, like http://elfadistrelec.com, http://digikey.com, http://tme.eu to mention a few.
Mouser Shopping Cart
All components below except LED resistor, transformers, tube sockets and tubes have been placed in this Mouser shopping cart: https://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=b93f29a67d
The BOM and shopping cart were last updated 2019-04-03, ensuring that everything is in stock.
Note that the 470uF/160V electrolytic capacitor has been replaced with a 200V version, and that the 100V ceramic capacitors have been replaced with 200V models.
The BSTRD Tube Pre:
Quantity | Component | Value | Mouser Part #, or other source |
2 | Resistor, 0.6W | 1k ohms | 279-LR1F1K0 |
2 | Resistor, 0.6W | 22k ohms | 603-MF0207FTE52-22K |
2 | Resistor, 1/4W | 100k ohms | 603-MFR-25FRF52100K |
2 | Resistor, 1/4W | 330k ohms | 603-MFR-25FBF52-330K |
2 | Resistor, 1/4W | 1M ohms | 603-MFR-25FRF521M |
2 | Electrolytic capacitors, 25V (≤10mm width, 5mm pin spacing) | 47 uF | 647-UKZ1E470MPM |
2 | Film capacitors (7.5mm pin spacing), ≥ 100V | 1 uF | 505-MKS41.0/100/10 |
2 | Ceramic capacitors | 0.1 uF | 80-C320C104K1R |
1 | Stereo Potentiometer, logarithmic, 16 mm | 100k ohms | 652-PDB182-K430K104A |
2 | Sockets, for tube | 8 pins | Search for "octal socket pcb" on eBay, Amazon etc. |
2 | Tubes, valves | 6J5 or equivalent | Available from various sources, such as eBay and other online stores. |
3 | Screw terminals | 3 ports | 651-1705469 |
Alternative tubes that can be used with this preamp are:
- L63
- 6S2S (Russian tubes, also known by the Cyrillic 6C2C)
- 7A4
- CV1067
- 12J5 (needs 12V filament heater)
The BSTRD Power Supply:
10 | Diode | 1N4004 | 821-1N4004 |
1 | Resistor, 2W | 180 or 200 ohms | 71-CPF2200R00FKE14 |
1 | Resistor, 1/4W | 100 ohms | 603-MFR-25FRF52100R |
1 | Resistor, 1/4W | 820 ohms | 603-MFR-25FTE52-820R |
1 | Resistor, 1/4W | 3k3 ohms | 603-MFR-25FRF52-3K3 |
1 | Resistor, 1/4W | 6k2 ohms | 603-MFR-25FRF52-6K2 |
1 | Resistor, 1/4W | Suitable for LED @6.3V | Calculate here |
4 | Electrolytic capacitor, 100V (≤13mm width, 5mm pin spacing) | 390 uF | 661-EKZN101E391MK35S |
1 | Electrolytic capacitor, 100V (≤13mm width, 5mm pin spacing) | 47 uF | 647-UHE2A470MPD |
1 | Electrolytic capacitor, 200V (≤18mm width, 7.5mm pin spacing) | 470 uF | 647-UCY2D471MHD |
4 | Electrolytic capacitor, 25V (≤13mm width, 5mm pin spacing) | 3300 to 3900 uF | 661-EKYB250E392MK40S |
1 | Electrolytic capacitor, 16V (≤5mm with, 2.5mm pin spacing) | 47 uF | UKZ1E470MPM1TD |
4 | Ceramic capacitor | 0.1 uF | 80-C320C104K1R |
1 | Voltage regulator, TO-220 | TL783 | 595-TL783CKCSE3 |
1 | Voltage regulator, TO-220 | LT1086 (or LM317) | 512-LM317T |
2 | Heat sink | SK104 | 567-637-20ABPE |
2 | Heat sink mounting kit | TO-220 | 532-4880SG |
3 | Screw terminal, 5 or 5.08 mm pin spacing | 2 ports | 651-1711725 |
1 | Screw terminal, 5 or 5.08 mm pin spacing | 3 ports | 651-1705469 |
1 | Transformer, ≥ 15VA | 6 V AC (or up to 12V) | The print on the PCB says 9-12V. but 6-9V is better suited. |
1 | Transformer, ≥ 10VA | 18 V AC (or up to 24V) | The print on the PCB says 21-24V, but 18-21V is better suited. |
Transformer options are not given in the shopping cart, as there is too many choices depending on input voltage and designs. However, this one should work for 115-230V AC input and both 9V (parallel) and 18V (serial) AC output:
Also note, it's better to get transformers with lower output than stated on the PCB. The reason for this is that many transformers output a higher voltage than stated due to higher than nominal mains voltage.
are you saying use the same transformer twice (buy 2); for the 15va and 10va?
https://www.mouser.com/ProductDetail/Triad-Magnetics/VPT18-1390/?qs=sGAEpiMZZMvwUzoUXIIvyTw34uqMHR%252buJampnWcUvS4=
Yes, you need two transformers. The one I linked to has two 9V secondary outputs, you can connect the secondaries in parallel for 9V and series for 18V:
https://www.electronics-tutorials.ws/transformer/multiple-winding-transformers.html
Please check the 3 ports screw terminals when ordering, because all I received were the 2 ports terminals! I could use them after modification, but still….
