Boards Received, Construction of Preamp Board
A project log for The Muffsy BSTRD - Class A Valve Preamp
An open source Class-A valve preamplifier and regulated PSU, complete with Eagle project files and detailed Bill of Materials
skrodahlskrodahl • 11/28/2016 at 20:58•0 Comments
There's been a little progress, now that the PCBs arrived today.
The heat sinks fit nicely, and coupling two 2-port screw terminals together worked out nicely:
Everything fits as it's supposed to, and I like having ceramic components on a PCB. I really think they look the part.
The only thing left to do on the preamp board is fitting the tubes:
There you have it, one preamp fully assembled. Next up is the power supply.
