- Thermal frames timestamps improved. Now the frame timestamp is taken when the frame is created on ESP.
- Bug fix: previously, Web UI might show thermal frames with some delay that could accumulate with time. Now frames are shown closer to real time.
- The ESP8266 processor frequency is increased to 160 MHz, which seems to help when multiple web clients are connected.
- The previous version could not work on the latest NodeMCU. Now it should work fine on 1.5.4.1 - 3.0.0.
- Web UI is now responsive, so it is more usable on mobile phones.
- Code size is slightly smaller, which is useful on ESP modules with small EEPROM (512k).
dev-lab
