A homebrew computer built around the 68010 with the companion 68451 MMU
68451_Memory_Management_Unit.pdfManual for the 68451Adobe Portable Document Format - 2.40 MB - 11/05/2020 at 23:58 |
I've found exactly one example of schematics of a machine that used the 451 at https://archive.org/details/bitsavers_compuproA1nualNov83_1763479/page/n7/mode/2up
Unisoft was a company in the 80's that ran around porting UNIX to various things, and they have a version of UTSv7 on bitsavers: http://bitsavers.org/bits/Unisoft/V.1.5+/sys/
and finally, the retrobrew community has peripheral boards and compute boards that use the 68000. Presumably we can shoehorn the 68010 in to there (it was pin compatible) with the 451 in between https://www.retrobrewcomputers.org/doku.php?id=boards:ecb:mini-68k:start
I've poked at this idea myself, ever since I saw the MMU. From what I can tell, between the 68000's botched page fault handling, and the limited capabilities of the 68451, most system designers used their own MMUs. That S-100 card's a good find, though I had a thought of using VMEBus. After all, it was designed for backplane 68000 machines from the start.
Hi John, there's some documents in the hardware directory on Aminet that cover swapping their 68000s over to 68010s, so you may find them of use when using an 010 in an 000 design.
Thank you for the information. I would like to try this one day
