Hackaday.io Hackaday.io
Sign up Log in
68010 / 68451 MMU Homebrew
A homebrew computer built around the 68010 with the companion 68451 MMU
john-sonnenscheinJohn Sonnenschein
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
1.7k views
3 comments
12 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 3
View Gallery
Public Chat
1.7k
3
12
8
Team (1)
  • john-sonnenscheinJohn Sonnenschein
Join this project's team
  • KiCAD files
hardware
ongoing project
68k m68k MMU RETRO 68451 m68451 m68010
Related lists
68k Machines
Retro Designs for 68000 Family CPUs (that I find interesting)
This project was created on 01/15/2020 and last updated 6 years ago.
Description
the 68451 MMU was made as a companion for the 68010 CPU, Motorola's first CPU to support virtual memory. There are very few examples of machines built with this combination, and neither Linux nor NetBSD support it (yet). Most 68010 machines were either built with no MMU at all (being a minor upgrade from the 68000), custom MMU's (for instance the Sun-2), or the generation was skipped entirely for later M68k CPU's that included on-chip MMU.
Files
68451_Memory_Management_Unit.pdf
Manual for the 68451
Adobe Portable Document Format - 2.40 MB - 11/05/2020 at 23:58
Preview
Project Logs
Collapse
  • Early research
    John Sonnenschein • 03/01/2020 at 21:40 • 0 comments
    I've found exactly one example of schematics of a machine that used the 451 at https://archive.org/details/bitsavers_compuproA1nualNov83_1763479/page/n7/mode/2up
    Unisoft was a company in the 80's that ran around porting UNIX to various things, and they have a version of UTSv7 on bitsavers: http://bitsavers.org/bits/Unisoft/V.1.5+/sys/
    and finally, the retrobrew community has peripheral boards and compute boards that use the 68000. Presumably we can shoehorn the 68010 in to there (it was pin compatible) with the 451 in between https://www.retrobrewcomputers.org/doku.php?id=boards:ecb:mini-68k:start
View project log
Log In/Sign up to comment
Sign up with Github
OR
ramon_blake wrote 04/28/2024 at 21:00 • point
Thank you for the information. I would like to try this one day
Watchm4ker wrote 04/12/2020 at 09:07 • point
I've poked at this idea myself, ever since I saw the MMU. From what I can tell, between the 68000's botched page fault handling, and the limited capabilities of the 68451, most system designers used their own MMUs. That S-100 card's a good find, though I had a thought of using VMEBus. After all, it was designed for backplane 68000 machines from the start.
RW wrote 03/01/2020 at 22:17 • point
Hi John, there's some documents in the hardware directory on Aminet that cover swapping their 68000s over to 68010s, so you may find them of use when using an 010 in an 000 design.
The MCL86+ is an open-source drop-in emulator for the Intel 8088 which uses a Teensy 4.1 and a small PCB
Project Owner Contributor
MCL86+ Drop-in Intel 8088 Emulator and Accelerator
ted-friedTed Fried
A retrocomputer and CPU exerciser for classic 8-bit CPUs.
SDC_One
gbmgbm
Homebrew Motorola 68k single-board computers running mainline Linux
Mackerel-68k Linux SBCs
colin-maykishColin Maykish
X65 - modern 8-bit computer for the modern era :: 65C816, 16MB RAM, 256 colors 384×240px, FM-synth, USB…
X65 Microcomputer
tomasz-sternaTomasz Sterna
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "68010 / 68451 MMU Homebrew", please tell us the reason.
Send message
Remove Member
