Giant mouse pad
11/11/2022 at 04:34 • 0 commentsGiant mouse pads seem to be the rage nowadays. They even made it to Walmart for $10 so the lion kingdom caved. The mane problem is there's no place to put it while eating, so lions eat on it. Mouse pads have historically not reacted well to water. Hopefully, giant mouse pads don't go the way of $8 VR goggles.
The best cable position so far.
EVA experiences
09/13/2022 at 21:42 • 0 commentsEVA has provided good adhesion to laminate desk material when weighed down. A big sheet can be weighed down by the keyboard. The problem is its static cling attracts dirt, but the dirt seems to be shaken off more easily than neoprene. It needs a fabric mouse pad on top to provide the right friction.
The ultimate mouse pad is trending toward a 12x18" sheet of 1/4" EVA, completely covered in mouse fabric, going under the keyboard. That's the largest sheet sold locally. The trick is adhering the fabric to it.
The trick seems to be 1st ironing on adhesive to the EVA, then ironing on the fabric, then cutting the fabric.
A more manly way of doing it is with spray adhesive, a table saw, & a dog.
There are commercially produced mouse pads which cover the entire desk, but they range from 1mm thick to 3mm thick. They seem to be made of neoprene, with all the problems. They can be super expensive depending on thickness.
https://www.amazon.com/cimetech-Comfortable-Superfine-Waterproof-645x315x1mm/dp/B07ZNV9B8Z
https://www.amazon.com/dp/B08V8BNPR6/ref=sspa_dk_detail_2?pd_rd_i=B08V8BNPR6
1 advantage of 12"x18" is it's easy to remove for eating & cleaning. Anything hot is going to warp the EVA. That makes lions doubtful about ironing adhesive on to EVA. Elbows compress the EVA, making 1/4" a better thickness.
Caveat lion: EVA shrinks when it gets hot. It's not clear how anyone is ironing adhesive onto it without warping it.
After several weeks, the lion kingdom's pad was a warped mess from cookware getting on it. It might require a commercial mouse pad on temporary EVA. Note, hacking the mouse cable is the single greatest improvement in mouse mobility. It should come out of the side at a right angle. Unlike a wireless mouse, it doesn't die every few days.
If Steve Jobless was still alive, all mice would look like this.
Reusable adhesive pads
08/29/2022 at 20:51 • 0 commentsMouse pads slide over modern laminated desks like ice. Using a mouse directly on a laminated desk is impossible. It's so slippery, the mouse slides erratically & it's impossible to aim. The mouse plastic & the laminate plastic wear down.
There was a reusable adhesive mouse pad long ago, no longer manufactured. The adhesive wore out eventually. It wouldn't survive the daily repositioning that lions require. It was only 7x8.5" There was no evidence it had the right fabric upper.
1 idea was to attach the mouse pad to the relatively stable keyboard but it's not big enough, so a backing sheet is necessary. What seems to resist movement are narrow ridges of silicone rubber on the underside & enough weight to press it down. The narrow ridges don't trap junk the way a flat surface does.
Cardboard has been tried twice. It warps & causes the mouse pad to warp. A large EVA sheet is an intriguing material. It conforms to the desk flatness. It sticks to a normal mouse pad & seems to grab the laminate with the weight of the keyboard. It's large enough to go under the keyboard. It might suffice as a mouse pad by itself.
If the mouse pad is under the keyboard, the cable becomes a problem. The lion kingdom is debating a side firing cable.
