Step Stick External Buffer
Board to buffer Step Stick Socket Signals for Off-Board Drivers
There are a number of Step-Stick breakout boards to allow the nearly ubiquitous Step-Stick compatible controllers to control off-board drivers. But many off-board drivers like 5V and higher power. This is a simple board to provide a level shift and higher current(16mA) for off-board drives. The Step, Direction and Enable pins are sent to the Motor pins.
Kicad Files, untested: https://github.com/wormley/stepbuffer
  • 1 × SN74LV4T125
  • 1 × 2uF SMT Capacitor
  • 2 × 8 pin headers
  • 1 × 2x3 Header
  • Made one
    Steve • 05/02/2020 at 21:39 • 0 comments
    Made one, need more notes on the silk screen on the PCB on how to assemble and insert, but it works.
  • Parts on the way
    Steve • 01/21/2020 at 18:47 • 0 comments
    Mouser order with headers, SN74LV4T125 and Capacitors arrived.
    Boards still in production.
View all 2 project logs
