Using a rotary crown to program a digital watch - all in a shiny case.
Thank you! The case is this: http://www.ofrei.com/page523.html
I did look at those manufacturers, and just took another look. I see some reference to sensing fields that are parallel, but all diagrams related to rotation I have seen for those manufacturers have the field orthogonal to the chip. I’m not expert at this - could you point out what language to look for among the melexis chips linked below?
Thank you for the link.
You could use the TLE493
See the figure 2 YZ config:
That is really nice. I am interested which casing did you use?
Also for the magnetic sensor, you can find xyz sensors by infineon or melexis that does not require to be faced to the magnet, it would be easier as you wont need an 90angle PCB ;)
