AC Voltmeter using Arduino
We are going to create an AC Voltage Measuring Device using Arduino, which will estimate the voltage of Alternating Current.
Arduino AC Voltmeter will calculate the voltage of Alternating Current. This post reveals how to build a simple AC voltmeter that includes AC voltage with Arduino UNO board where voltage value is printed on 16×2 LCD.
                                                          Circuit Diagram
Working of Project
1. Step down voltage is obtained on the l.v side of the transformer which is fit to utilize across normal power rating resistors.
2. Then we receive specific voltage value across the 4.7k resistor.
3. Arduino utilizes this voltage as input from pin A0 in the form of analog values between 0 to 1023. 0 is considered as 0 volt and 1023 being 5v.
4. Arduino then changes this analog value into corresponding mains a.c. voltage by a formula.
n=(311/1023)*m volts or n=(m*.304177)
IoT Training Online will give a thorough view of IoT Applications.
  • 1 × Power Managment IC, Transformer
  • 1 × 1N4007 – High Voltage, High Current Rated Diode
  • 1 × Capacitor 1 µF
  • 1 × Zener Single Diode, 5.1 V
  • 1 × Arduino UNO & Genuino UNO
View all 7 components
  • 1
    Run a Code
    int m;  // initialise variable m
    float n; //initialise variable n
    void setup()
    pinMode(A0,INPUT);  // set pin a0 as input pin  Serial.begin(9600);// begin serial
                                           communication between Arduino and pc
    void loop()
    m=analogRead(A0);   // read analog values from pin A0 across capacitor
    n=(m* .304177);    // converts analog value(x) into input ac supply value using this
                                formula
    Serial.print("   analaog input  " ) ;   // specify name to the corresponding value to
                                                             be printed
    Serial.print(m) ; // print input analog value on serial monitor
    Serial.print("   ac voltage  ") ; // specify name to the corresponding value to be
                                                      printed
    Serial.print(n) ; // prints the ac value on Serial monitor
    Serial.println();
View all instructions
prty286 wrote 06/30/2023 at 05:32 • point
Great project! I'm impressed by your AC voltmeter using Arduino. It's a creative way to monitor electrical voltages. By the way, have you considered incorporating an  ac cleaning feature to ensure optimal performance? Keep up the good work!
