1Run a Code
int m; // initialise variable m float n; //initialise variable n void setup() { pinMode(A0,INPUT); // set pin a0 as input pin Serial.begin(9600);// begin serial communication between Arduino and pc } void loop() { m=analogRead(A0); // read analog values from pin A0 across capacitor n=(m* .304177); // converts analog value(x) into input ac supply value using this formula Serial.print(" analaog input " ) ; // specify name to the corresponding value to be printed Serial.print(m) ; // print input analog value on serial monitor Serial.print(" ac voltage ") ; // specify name to the corresponding value to be printed Serial.print(n) ; // prints the ac value on Serial monitor Serial.println(); }
hIOTron
