Power source
A project log for PiBox
Just a conversion from an empty drill bit case to a Raspberry Pi laptop by laser cutting some inserts and plugging things together.
rich-maynardRich Maynard • 01/24/2020 at 10:57•0 Comments
I chose this power source as it can provide 5v via the USB connector, but also has onboard solder pads to provide 5v, 9v and 12v which might be useful for projects
https://www.aliexpress.com/item/32968744615.html
I used a couple of 18650s reclaimed from an old laptop battery pack
