HID_Touch_A031219.zip
USB HID (Keyboard) example with bootloader activation when the TIN2 touch key is activated (SDCC source code).
x-zip-compressed -
10.45 kB -
02/01/2020 at 10:24
Download
touchkey_A031219.zip
Touch Key example with bootloader activation when the USR key is pressed (SDCC source code).
x-zip-compressed -
3.52 kB -
01/31/2020 at 13:29
Download
blink_prog_A031219.zip
Blink example with bootloader activation when the USR key is pressed until blink stops (SDCC source code).
x-zip-compressed -
2.21 kB -
01/29/2020 at 21:12
Download
blink_A031219.zip
Blink example (SDCC source code).
x-zip-compressed -
1.83 kB -
01/29/2020 at 21:11
Download
CH552 Datasheet_C111367.zh-CN.en.pdf
CH552 Datasheet English-ish. Not a great translation, only to see the differences with CH554. Better use the CH554 Datasheet to start.
Adobe Portable Document Format -
1.47 MB -
01/30/2020 at 08:24
Preview
A031219 - SCH.pdf
Schematic
88.41 kB -
01/31/2020 at 15:04
Preview
A031219 - PCB Layout Guide.zip
PCB Assembling Guide
x-zip-compressed -
380.15 kB -
01/28/2020 at 16:38
Download
A031219 - Gerber.zip
Gerber files for PCB production
x-zip-compressed -
145.79 kB -
01/28/2020 at 16:39
Download
A031219_2x_Pannel_V-Cut_Gerber.zip
Gerber files with 2x panellization for V-Cut (added 1mm of space between the two boards for the cut)
x-zip-compressed -
267.67 kB -
01/30/2020 at 10:59
Download
A031219 - BOM.ods
BOM file
spreadsheet -
20.85 kB -
01/28/2020 at 16:38
Download
