I made a PCB business card which powers a microcontroller using NFC. It also transmits my contact info over NFC! Runs an ST25DV64K for NFC and energy harvest, zener diode voltage regulator & an STM8L101F3 low power 8 bit MCU to toggle LEDs. Check out my original reddit post with a GIF showing it in action: https://www.reddit.com/r/electronics/comments/efz9xf/my_nfc_powered_blinky_business_card/
Files
NFC Card Schematic.pdf
Adobe Portable Document Format -
88.81 kB -
01/27/2020 at 03:06
Yes, it's a PCB trace antenna. ST has good documentation on how to draw it so that it matches the required inductance. There's even a edesignsuite tool that helps. I'm a big fan of ST documentation. https://www.st.com/resource/en/application_note/an2972-how-to-design-an-antenna-for-dynamic-nfc-tags-stmicroelectronics.pdf
That is convenient! What a thorough document. Nice to have since I know nothing about antenna design. I am thinking of trying both this, and a basic rectification circuit instead of the ST25. It'd be nice if it could just work with a few caps and diodes. I am not sure I know how to program the ST25 if it comes to that.
Really cool project. How much power are you able to harvest with the current design? and is the project open source? I wanted to created something like this but with a twist it will save with the layout.
Awesome project. Could you share any details on how you did the antenna? Looks like its in the PCB.
