1Background Research
Some sources of information:
- Tech Ingredient's series on building transducer-based speakers (YouTube)
- Exciters & Tactile Transducers 101 (Parts Express)
- Surface Transducer specification sheets (DAEX30HESF-4)
- Speaker building forums & various threads discussing surface transducers (Rich Meinke's build post)
2Surface Transducer Selection
My research is limited to Dayton Audio's models, but they are the only "good" ones as far as I know.
Size 12mm 25mm High Efficiency Spider Feet Low Impedance The high efficiency variant seems to produce high volume and balanced frequency response - and it's the one I chose.
Jason Cho
