Voltage Levels
- HC logic chips data sheets say VCC may be as low as 2v typically
- HCT data sheets quote 4.5v as lowest Vcc but this is merely the min in order to maintain TTL compatibility. In reality HCT will run fine at lower Vcc.
- LS will also run at lower voltages. See http://www.ti.com/lit/an/sdya009c/sdya009c.pdf - _Texas Instruments - Designing With Logic_ Section 2.2 Behavior With Low Supply Voltages: _"TTL devices attain stability with a supply voltage of about 3.5v, and are fully functional at a typical voltage of 4v"_
HC/HCT/LS will all run fine at lever voltages than 5v. This is handly because there will be a voltage drops below 5v when powering and driving the test chips from the GPIO pins.
On the Zif socket I measured a voltage of 4.7v-4.8v with a 5v supply. This voltage drop was less than I expected. - The MCP23017 extender documents a high level output voltage of Vdd-0.7v, but perhaps thats a conservative value or perhaps I was measuring test pins driven by the Arduino...
- The ATmega328P documentation guarantees a high of at between 4.7v and 4.8v on a 5v supply at 10mA load. 2mA would be 4.9v or more. See page http://ww1.microchip.com/downloads/en/DeviceDoc/Atmel-7810-Automotive-Microcontrollers-ATmega328P_Datasheet.pdf "Figure 29-10. I/O Pin Output Voltage versus Source Current"
In anycase it's convenient that I'm seeing reasonable voltages on the Zif vs the needs of the various logic families.
EasyEda
- Its fun
- Its time sink
- The power and ground lines should be made wider than defaults - use design rules - Tweak the default track separation and track width so they are more robust and lower resistance - use design rules
- Check the design rules violations list for clearance errors before committing
Arduino Nano
- There is sufficient capacitance on the GPIO pins and lines out to the Zif socket that writing to a disconected pin (empty Zif) and then reading that same pin returns the logic level that was previously written, rather than a random value. See below for more information.
- The analog A6/A7 lines cannot be used as digital outputs, just digital inputs only
- The I2C pins SCL/SDA are open collector and need pull ups - but see more below
- D13 is connected via a 1k resistor and an LED to ground so this can interfere with it's reliability as a digital input due to the pull down. IF it is to be used at al then it is intended to be used as an output. - The header pins supplied with the Elegoo Arduino nano don't fit in a round pin DIP socket and the header pins are made of a metal that doesn't solder easily
- There is a lot of confusing discussion on whether one needs to add pullups to the I2C bus lines
So, do I or don't I need pullup resistors on the I2C lines SDA/SCL?
There is a lot of confusing info on this online.
Firstly, I found this explanation of why some kind of pullup MUST be present .... - "I2C bus drivers are "open drain", meaning that they can pull the corresponding signal line low, but cannot drive it high. Thus, there can be no bus contention where one device is trying to drive the line high while another tries to pull it low, eliminating the potential for damage to the drivers or excessive power dissipation in the system. Each signal line MUST HAVE a pull-up resistor on it, to restore the signal to high when no device is asserting it low."
However, the I2C pins on the Ardunio have built-in optional pull-up resistors. Fortunately, the "Wire library" turns on the internal pull up resistors in it's twi_init() called by Wire.begin() function on SDA & SCL. Doing this puts a weak-pull up on the I2C pins even though they are acting as outputs. Further digging explains that it is possible to have these digital input pull-ups turned on despite the pins acting as I2C outputs because the digital IO circuitry that contains the pull-up is in parallel to the I2C IO circuitry so they are not exclusive. Convenient!
And, for a physically short bus and where the voltages on each end are the same then a design doesn't need additional external pullups on the I2C pins.
Stray Capacitance test result
I tested what would happen if I left the Zif socket empty then set the GPIO as output and wrote a 1's to all the pins. I then turned the pins into inputs and measured the logic level every few seconds to to see what unfolded.
I've included the test results for my soldered PCB below.
Testcase : 1111111111111111111111 Result : -1111111111111111111111- : 0 secs Result : -1111111111111111111111- : 1 sec Result : -1101111111111111111111- : 2 secs Result : -0001111111111111111000- : 6 secs Result : -0000000000000110000000- : 10 secs Result : -0000000000000010000000- : 15 secs Result : -0000000000000010000000- : 20 secs Result : -0000000000000000000000- : 25 secs
Further run ...
Testcase : 1111111111111111111111 Result : -1111111111111111111111- : 0 secs Result : -1111111111111111111111- : 1 sec Result : -1001111111111111111111- : 2 secs Result : -0001111111011111111000- : 6 secs Result : -0000000100000111000000- : 10 secs Result : -0000000000000010000000- : 15 secs Result : -0000000000000010000000- : 20 secs Result : -0000000000000010000000- : 25 secs
What I see is that reading the pins echo's back the logic levels that were written to them moments before. We can see that at time passes the memory decays and the pins gradually start reporting logic 0. This decay consistently takes around 25 seconds to complete.
Running this same test over and over I found that the same pattern of decay to 0 was consistent on each run. I guess this is a consequence of each path having it's own unique RC.
