A wearable hexagonal sigil you can modify your backpack with.
3d-printer-files.zipThis includes all the STL files and openscad code to generate the componentsx-zip-compressed - 33.80 kB - 02/02/2020 at 21:14 |
HexSigil-Mini-1.0A.zipGerber files for fabricating the component boardx-zip-compressed - 24.74 kB - 02/02/2020 at 20:25 |
Fairly straightforward, you can find all the parts in the zip file attached to this project page (or on thingiverse https://www.thingiverse.com/thing:4140998)
You will simply need to print one of each item. Here's a description of the item and specific material notes:
Once you receive an empty PCB based on the gerber files, you can go ahead and solder the components. (I will add detailed instructions later). The components you need are listed in the component section of this project.
