build it up
02/15/2020 at 17:04 • 0 commentsi did the cutouts in the housing
assembled the connector and secured it with hot glue
disassemble power bank adapter
02/11/2020 at 21:17 • 0 comments
This is the PCB inside of the power bank adapter. There are 2 identical supplies for the USB ports. You clearly see the inductors of the buck converters. I want to use the XT60 connector for my project because my solder station (TS100) has an adapter for the XT60 connector.
The distance between the solder points from the battery also fit very well to the pitch of the XT60 connector.
To connect to the battery pack they use a common connection plate and cables.
The next time we adapt the housing for the XT60 connector.
begin with the basis
02/06/2020 at 05:37 • 0 commentsI ordered a Makita replacement battery and an power bank adapter for Makita batteries. It has two USB ports for charing your phone or tablet.
Next step is to disassemble this power bank adapter.
Tom
