IT VERKS!
04/01/2020 at 23:37 • 0 commentsFinally. Fixed the design. Got the new boards in. Soldered it up. Uploaded the code. AND IT WORKS!
Just gotta build the wooden stand for it.
Why would you double-check your work?
03/23/2020 at 00:45 • 0 commentsWell, I goofed.
I drew up my circuit wrong. Which meant the board was wrong. Then to top it off, I think I reflowed it at too high of temp and cooked some of the APA102Cs that are going on this thing. Live and learn.
I was able to "fix" both of the problems with the board layout enough to test everything and make sure it worked, enough. But now I have a new order for boards on its way. At least the layout didn't change so I can use the same stencil.
Coronavirus infects supply lines
02/20/2020 at 14:06 • 0 commentsI'm pretty sure I can blame the coronavirus on at least some of the delay I am experiencing in receiving parts. Ali Express, why have you forsaken me?!
