An XY mode scope-grab of sine and ring modulator signals. How often do you get to use XY, anyhow?
JPEG Image -
94.35 kB -
06/23/2020 at 14:58
Preview
Sine, cosine and ring modulator traces. Looks like I didn't manage to hold the camera perfectly still. Might also be time to clean the scope's screen, too.
JPEG Image -
97.70 kB -
06/23/2020 at 14:58
Preview
SineDriver.tar.gz
Complete KiCAD project file set. Includes an optional parallel port interface that, when paired with a raw printer device in CUPS, you'll have user-land access to the motors. Updated: 22 Jun 2020
application/gzip -
13.26 kB -
02/17/2020 at 18:42
Download
Motor_Printer_2.rb
This is a simple app to convert some G-Code (G0, G1) to a stream of control characters for the breadboard controller. The "SETUP" section contains the variables to edit for specifics of your system. Updated: 22 Jun. 2020
application/x-ruby -
14.22 kB -
03/12/2020 at 18:07
Download
It might not be pretty, but the motors are controllable from the command line.
JPEG Image -
131.03 kB -
02/17/2020 at 20:13
Preview
A dual 12V power supply, a quad op-amp, and four transistors make a motor spin. As shown, the circuit will put 5V RMS at 15 Hz on your stepper motor.
image/png -
74.66 kB -
02/10/2020 at 23:41
Preview
Even with a ring modulator, it is still no prettier. Now it has the building blocks color coded.
JPEG Image -
454.55 kB -
06/22/2020 at 18:42
Preview
