State of the project
02/19/2020 at 06:41 • 0 commentsA Renishaw TP-20 extended force touch probe was purchased. It came in two parts. The two parts mate together with balls, slots, magnets and spring pins. I cut apart the base part and was able to use parts from it to make a mechanical adaptor.
I found the pin on the BeagleboneBlack in the pocket nc that's hooked up to the tool height probe signal. I ran some G38.n gcodes, general straight probing gcodes. They all responded properly if I pushed the tool height probe by hand. I determined that by pulling down pin 22 on the BeagleboneBlack the probe signal could be actuated. I bread boarded a circuit to pull down the pin and to interface to the probe.I ordered some connectors.
The next steps are to add transient voltage suppression measures into the circuit, to make the circuit more permanent, enclose the circuit (probably will make a new cover for the PocketNC electronics bay), and add strain relief on the probe end of the probe cable.
