Hack and Decker Coffee Machine
A log of my attempts to hack/reverse engineer a Black and Decker coffee machine
  • 1 × Black and Decker Coffee Machine
  • Opened
    Ian Shannon Weber • 02/22/2020 at 05:13 • 0 comments
    There is a processor in the base of the coffee machine that controls the heating relay. I have two options moving forward: (1) Replace the control board or (2) figure out home to program the black and decker microcontroller.
    After using my new security bits I was able to crack open the machine. I noticed an interesting pattern on the bottom of the machine from Black and Decker milling their molds. (The base of my bits are in the background.)
View project log
  • 1
    Open the Coffee Machine
    Use a long (read over 1 inch/25.4 mm) two prong security bit and a Philips screwdriver to remove the screws from the bottom of the machine. Then press in the grey rear tabs. Finally then use a flat head screw driver help pry open the grey bottom from the black machine.
View all instructions
