1Open the Coffee Machine
Use a long (read over 1 inch/25.4 mm) two prong security bit and a Philips screwdriver to remove the screws from the bottom of the machine. Then press in the grey rear tabs. Finally then use a flat head screw driver help pry open the grey bottom from the black machine.
Ian Shannon Weber
