Hackaday.io Hackaday.io
Sign up Log in
Bats 'n Gons
Nocturnal flying mammals, geometric shapes, and emergent behavior
ted-yapoTed Yapo
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
8 comments
14 followers
  • Description
  • Details
  • Files 8
    • View all
  • Components 0
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 8
View Gallery
Public Chat
835
8
14
12
Team (2)
  • ted-yapoTed Yapo
  • sophi-kravitzSophi Kravitz
Join this project's team
  • Bats-n-Gons
ongoing project
This project was created on 02/22/2020 and last updated 5 years ago.
Files
bats-n-gons.lbr
lbr - 101.38 kB - 01/29/2021 at 17:08
Download
Bats-n-Gons.sch
sch - 213.55 kB - 01/29/2021 at 17:08
Download
Bats-n-Gons.brd
brd - 127.40 kB - 01/29/2021 at 17:08
Download
IS31AP4991.pdf
audio amplifer
Adobe Portable Document Format - 416.82 kB - 03/07/2020 at 21:33
Preview
SophiEaglev9.lbr
lbr - 279.10 kB - 03/05/2020 at 16:23
Download
View all 8 files
Project Logs
Collapse
  • Bootloader update
    Sophi Kravitz • 01/29/2021 at 17:10 • 0 comments
    Using J-link
    GCC ARM toolchain
    -add pullup to 5V
    -tie SAMD51 vref to 3.3V for analog audio
  • UF2 Bootloader Links
    Ted Yapo • 03/21/2020 at 03:00 • 0 comments
    The UF2 bootloader is neat in that it exposes a USB filesystem that you can simply drag-and-drop files into from your host OS. Here are some links to resources for building and burning:
    Building
    https://www.hackster.io/wallarug/uf2-bootloader-creating-custom-boards-c9620c
    Burning
    Using Atmel Studio (Windows Only)
    https://learn.adafruit.com/how-to-program-samd-bootloaders?view=allow-to-program-samd-bootloaders?view=all
    Using Command Line (Hopefully Linux, too)
    https://forums.adafruit.com/viewtopic.php?f=57&t=142170&p=707151#p707151
  • Important Links
    Sophi Kravitz • 03/03/2020 at 23:14 • 0 comments
    Soundboard in 10 minutes
    BOM
    Github
    How to build Circuit Python. Hint: look at Trinket config file to configure external flash.
  • Functionality/ spec list
    Sophi Kravitz • 02/28/2020 at 17:22 • 0 comments
    This is a SAMD51 Cortex M4 with space for a small bat sound (we're testing 512 kB and 1 mB).
    • Sound / speaker
    • 2 LEDs
    • 4 wire connector for communications with D+, D-, V, GND
    • Circuit Python compatible
    • Capacitive touch sensor
    • Easter eggs
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
OR
James Finch wrote 03/19/2020 at 18:39 • point
I'm still waiting for my Digikey, Knowles FG-23629-P16 transducer, backordered.  The MEMS SPU0410LR5H came in and I tested to see how they fit flush mount on a PCB. Next month, the 384kHz sampling rate USB Sound Card (I think SB G6) though am way noob seeing TI has a 786kHz sampling rate ADC and am wondering if I'd like to see more frequency range at a time?
Dusan Petrovic wrote 02/24/2020 at 14:01 • point
I'm watching this with great interest!
Sophi Kravitz wrote 03/04/2020 at 16:23 • point
you may get to see it IRL
Dusan Petrovic wrote 03/04/2020 at 16:37 • point
Really? That would be awesome. Can't wait to see it!
Lizard Breath wrote 02/23/2020 at 01:40 • point
is it a hardware project?
Ted Yapo wrote 02/23/2020 at 16:20 • point
yes!
Simon Merrett wrote 02/22/2020 at 20:41 • point
No details, no logs yet. But this sounds exciting!
Ted Yapo wrote 02/23/2020 at 16:21 • point
the possibilities are endless!
GUI interface (ImGUI) for send text over radio using SDR or Transciever with Minimodem
Project Owner Contributor
Minimodem-ImGUI
yd1ruhYD1RUH
Follow along
Intel Edison tips and tricks
Writing and executing a 'C' program for the Linux core using the WiringX library.
Linux on the MILK-V Duo - WiringX
canhobbycaCanHobby.ca
Visualization of sound waves in the TinyLev acoustic levitator, using standard schlieren photography
Visualize Sound-001: TinyLev & Schlieren Method
earlwallacenycearlwallacenyc
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Bats 'n Gons", please tell us the reason.
Send message
Remove Member
