Bootloader update
01/29/2021 at 17:10 • 0 commentsUsing J-link
GCC ARM toolchain
-add pullup to 5V
-tie SAMD51 vref to 3.3V for analog audio
UF2 Bootloader Links
03/21/2020 at 03:00 • 0 commentsThe UF2 bootloader is neat in that it exposes a USB filesystem that you can simply drag-and-drop files into from your host OS. Here are some links to resources for building and burning:
Building
https://www.hackster.io/wallarug/uf2-bootloader-creating-custom-boards-c9620c
Burning
Using Atmel Studio (Windows Only)
https://learn.adafruit.com/how-to-program-samd-bootloaders?view=allow-to-program-samd-bootloaders?view=all
Using Command Line (Hopefully Linux, too)https://forums.adafruit.com/viewtopic.php?f=57&t=142170&p=707151#p707151
Important Links
03/03/2020 at 23:14 • 0 commentsHow to build Circuit Python. Hint: look at Trinket config file to configure external flash.
Functionality/ spec list
02/28/2020 at 17:22 • 0 commentsThis is a SAMD51 Cortex M4 with space for a small bat sound (we're testing 512 kB and 1 mB).
- Sound / speaker
- 2 LEDs
- 4 wire connector for communications with D+, D-, V, GND
- Circuit Python compatible
- Capacitive touch sensor
- Easter eggs
