Features
- ESP32 breakout board
- Requires specific version of ESP32 board (marked ESP32 DEVKITV1 on bottom)
- GVS (Ground, Voltage, Signal) for all ESP32 pins
- 4-channel I2C Hub
- TCA9544 - 4-Channel I2C and SMBus Multiplexer With Interrupt Logic
- Isolated I2C channels
- Interrupt for each I2C channel
- I2C Channels can be independently powered with 3.3V or 5V
- Jumper selectable I2C base address
- FTDI header
- SPI bus header
- 5V power source selection/distribution
- 5V sources - USB, 5mm terminal block, DC jack
- On-board 3.3V power regulator (doesn't stress the ESP32 regulator)
- 95x95mm ODAS form factor
- 6-32 mounting holes
land-boards.com
Abraham
andriy.malyshenko
Noritama
