I found why i went wrong in the beginning
07/28/2020 at 11:17 • 0 commentsI had some trooble with the RAID in the first place. its due to the USB drawing too much current so to fix this either use a powered USB hub or use only two USB stick with the max_usb_current=1 in /boot/config.txt then it run fine
So far so good
03/15/2020 at 11:53 • 0 commentsthe server is still running fine. i counted the number of request to 5 per seconds before crash. so you should be fine with up to three frequent user (we edit it all days long) and up to 10 user if you have htop displayed somewhere and people dont all click at the same time
Getting better
03/07/2020 at 16:16 • 0 commentsThe raid have been stable for 4 days now i believe it was because the raid was still initialzing at first.
i understood that the server freeze when too many request are processed at the same time. So if not everybody clink on the link at the same time and if only one update od the wiki is done at the same time it work fine. (i cant wait to receive a real server for this :')
getting barely usable
03/05/2020 at 08:19 • 0 commentsi finnally managed to have instruction that work out of the box.
i need to find why mysql go crazy with the CPU and freeze the whole thing.
i also need to mount the raid with uuid rather that /dev/sdX1 because they change and are not always detect by mdadm which cause crash
Nathann
