There are some options for assembling 6800 code today. Ideally, a cross assembler would be good from Windows.
Herb Johnson has adapted William C Colley III's A68 6800 cross-assembler. The A68 assembler runs in DOSBOX under Microsoft Windows.
Output Format
A68 produces Intel hex records which can be loaded into the Intel/Altera Quartus II FPGA tool.
Attempts to Assemble MIKSBUG
When I tried to compile MIKSBUG I got the usual pile of errors - 98 in fact.
Smithbug Compiles with A68
Smithbug from here code version V2_DIS_corrected.ASM is MIKBUG compatible and compiles with the A68 6800 cross-assembler without error.
a68 V2_DIS_corrected.ASM -l V2_DIS_corrected.LST -o smithbug.hex 6800/6801 Cross-Assembler (Portable) Ver 3.5! Copyright (c) 1985 William C. Colley, III fixes for LCC/Windows and improvement by HRJ Aug 26 2019 A68 source_file | -l list_file | | -o/-s object_file | No Errors
Changed the vector table to be at $CFF8 instead of $FFF8.
; ;END of V2 S-loader ; ; STARTUP VECTORS $FFF8 -$FFFF ; cff8 ORG $CFF8 ; cff8 c0 55 FDB IO cffa c0 5f FDB SWI cffc c0 5a FDB POWDWN cffe c0 00 FDB START
The end of the code is here:
c8ca a6 00 OUTSTR LDAA 0,X ; Read String c8cc 81 04 CMPA #$4 ; Is it EOT? c8ce 27 05 BEQ STEXIT ; Exit if EOT c8d0 8d eb BSR OUTPUTA ; Print Charactor c8d2 08 INX ; Point at next charactor c8d3 20 f5 BRA OUTSTR ; Loop and read next c8d5 39 STEXIT RTS ;
DOS command line to make hex file:
A68 ran in Windows 10 CMD window (didn't need DOSBOX). Start of the HEX file is:
:10C000008E7F44BF7F0A7F7F0DCEC125FF7F17FF44 :10C010007F088603B780180101018615B77F0CB62B :10C020007F0CB780188E7F448E7F627F7F137F7F67
End of the code looks like:
:10C8C00018575724F9B780193339A6008104270572 :06C8D0008DEB0820F53994 :08CFF800C055C05FC05AC00023 :00D000012F
This seems OK.
