MIKBUG is dropping a character during s-record-loads. Dropped baud rate from 115,200 to 9600 and it still drops character. RTS is not being de-asserted even when changing RTS buffer assertion levels so I don't think it's an overrun. I have seen RTS deassert on larger transfers.
Trace is using DS Logic Plus on Tx, Rx, RTS_N lines.
Load works OK at 2400 baud. Strange behavior.
6800 S-Record Load Assembly Code
S1STRING FCC "This S1 load has entered system scratch area" FCB $0D,$0A,$04 ; DGG - S Record loader SLOAD EQU * PSHA ; Save A register STX TEMPX1 ; Save X register ; DGG - Next line was BSR but fixing the CPX VAR lines made it too far away GOAGAIN JSR GETCHAR ; Get first character from ACIA ; Wait for an S CMPA #$53 ; Is it "S" BNE GOAGAIN ; If not go read again BSR GETCHAR ; Get second character in frame CMPA #$39 ; Is it "9" BEQ RECOVER ; If "9" go and end read CMPA #$31 ; Is it a "1" BNE GOAGAIN ; If no then go start again CLR TEMPA ; Clear Frame length BSR GETHEX ; Get frame length from input stream SUBA #$02 ; Subtract the checksum STAA BYTESTORE ; Save frame length BSR GETADD ; Read next two bytes for dest address GETCOUNT BSR GETHEX ; Get the byte number DEC BYTESTORE ; decrement counter BEQ INCOUNT ; If zero go to increment byte count STAA 0,X ; Store read byte into memory CMPA 0,X ; Test if RAM OK BNE QUESTION ; If write failed send Question and abort INX ; Increment address pointer ; DGG - CPX was CMPX which did not compile and was commented out ; DGG- Changed branch from BGE to BLE (I think the compare worked the other way) CPX VAR ; Is it the system scratch area BLE S1EXIT ; Abort if close to system scratch BRA GETCOUNT ; go get another byte ; S1EXIT LDX #S1STRING ; Protect System Scratch Abort S1 BSR OUTSTR ; Print abort string BRA RECOVER ; Back to console prompt ; INCOUNT INC TEMPA ; Increment tempa BEQ GOAGAIN ; If zero go for another frame QUESTION LDAA #$3F ; Load question mark JSR OUTPUTA ; Send to console RECOVER LDX TEMPX1 ; Restore "X" PULA ; Restore A JMP CONTRL ; Jump to exit ; ; GETADD BSR GETHEX ; Read in byte STAA ADDRESS ; store in first part of address BSR GETHEX ; Get another byte of data STAA ADDRESS1 ; store in second address register LDX ADDRESS ; Load X register both bytes of address RTS ; Return from sub routine ; ; ADD IN THE ADDRESS OFFSET ; GETHEX BSR CONVHEX ; Go get byte of data and convert to binary ASLA ; Shift the the 4 bits into msb ASLA ; Shift the the 4 bits into msb ASLA ; Shift the the 4 bits into msb ASLA ; Shift the the 4 bits into msb TAB ; Transfer "A" to "B" BSR CONVHEX ; Go get byte of data and convert to binary ABA ; Add 4 bits in "A" and "B" into "B" TAB ; Transfer "A" to "B" ADDB TEMPA ; Add into checksum STAB TEMPA ; Add into checksum RTS ; Return from sub routine ; CONVHEX JSR GETCHAR ; Get HEX character from ACIA SUBA #$30 ; Convert to binary BMI QUESTION ; Convert to binary CMPA #$09 ; Convert to binary BLE RETURN2 ; Convert to binary CMPA #$11 ; Convert to binary BMI INCSTACK ; Convert to binary CMPA #$16 ; Convert to binary BGT INCSTACK ; Convert to binary SUBA #$07 ; Convert to binary RETURN2 RTS ; Return from sub routine
Solution
Shut off the echo using "N" command and it works even at 115,200 baud.
Type "O" to turn on after transfer.
Need to turn off echo if using built-in INEEE routine from programs you write otherwise characters will be echoed. Alternately could Set/Clear ECHO flag. Might want to save ECHO flag.
0xf1f3 INEEE
0xf20a OUTEEE
