Wrote a small test program to get a character from the serial port and write it back to the serial port. Uses the MIKBUG serial in and out routines.
; TESTCODE.ASM ; DOS command line to assemble source ; a68 TESTCODE.ASM -l TESTCODE.LST -s TESTCODE.s ; & to download S-record to card ; Copy/paste into PuTTY terminal ACIACS EQU $FC18 ACIADA EQU $FC19 START ORG $0000 LBACK BSR GETCHAR BSR OUTPUTA JMP LBACK ; GETCHAR PSHB WAITIN LDAB ACIACS ; LOAD ACIA CONTROL REGISTER ASRB ; SHIFT RIGHT ACIADA BCC WAITIN ; IF CARRY NOT SET THEN AGAIN LDAA ACIADA ; LOAD DATA REGISTER PULB ; RESTORE B REGISTER RTS ; OUTPUTA PSHB ; SAVE B WAITOUT LDAB ACIACS ; LOAD ACIA CONTROL REGISTER ASRB ; SHIFT RIGHT ASRB ; SHIFT RIGHT BCC WAITOUT ; IF CARRY NOT SET DO AGAIN STAA ACIADA ; SEND CHARACTOR TO ACIA PULB ; RESTORE B RTS ; RETURN FROM ROUTINE END
Assembles to:
; TESTCODE.ASM ; DOS command line to assemble source ; a68 TESTCODE.ASM -l TESTCODE.LST -s TESTCODE.s ; & to download S-record to card ; Copy/paste into PuTTY terminal fc18 ACIACS EQU $FC18 fc19 ACIADA EQU $FC19 ; 0000 START 0000 ORG $0000 0000 LBACK 0000 8d 05 BSR GETCHAR 0002 8d 0f BSR OUTPUTA 0004 7e 00 00 JMP LBACK ; 0007 37 GETCHAR PSHB 0008 f6 fc 18 WAITIN LDAB ACIACS ; LOAD ACIA CONTROL REGISTER 000b 57 ASRB ; SHIFT RIGHT ACIADA 000c 24 fa BCC WAITIN ; IF CARRY NOT SET THEN AGAIN 000e b6 fc 19 LDAA ACIADA ; LOAD DATA REGISTER 0011 33 PULB ; RESTORE B REGISTER 0012 39 RTS ; 0013 37 OUTPUTA PSHB ; SAVE B 0014 f6 fc 18 WAITOUT LDAB ACIACS ; LOAD ACIA CONTROL REGISTER 0017 57 ASRB ; SHIFT RIGHT 0018 57 ASRB ; SHIFT RIGHT 0019 24 f9 BCC WAITOUT ; IF CARRY NOT SET DO AGAIN 001b b7 fc 19 STAA ACIADA ; SEND CHARACTOR TO ACIA 001e 33 PULB ; RESTORE B 001f 39 RTS ; RETURN FROM ROUTINE 0020 END fc18 ACIACS fc19 ACIADA 0007 GETCHAR 0000 LBACK 0013 OUTPUTA 0000 START 0008 WAITIN 0014 WAITOUT
S-Record file:
S11300008D058D0F7E000037F6FC185724FAB6FCD8 S113001019333937F6FC18575724F9B7FC19333913 S9030020DC
Downloaded to the card.
Works!
