TASK FORTH NOOP VLIST TRIAD INDEX LIST ? . D.
D.R .R #S # SIGN #> <#
SPACES WHILE ELSE IF REPEAT AGAIN END UNTIL
+LOOP LOOP DO THEN ENDIF BEGIN
BACK FORGET ' R/W HI LO BLOCK_READ BLOCK_WRITE
?DISC --> LOAD MESSAGE .LINE (LINE) BLOCK BUFFER
DR1 DR0 EMPTY-BUFFERS UPDATE +BUF PREV USE DABS
ABS M/MOD
*/ */MOD MOD / /MOD * S->D COLD ABORT QUIT
( DEFINITIONS VOCABULARY IMMEDIATE INTERPRET DLITERAL
LITERAL [COMPILE] CREATE ID. ERROR (ABORT) -FIND
NUMBER (NUMBER)
LABD______________ PAD HOLD BLANKS ERASE FILL
QUERY EXPECT ?STACK ." (.") -TRAILING
TYPE COUNT DOES> <BUILDS ;CODE (:CODE) DECIMAL
HEX SMUDGE ] [ COMPILE ?LOADING
?CSP ?PAIRS ?EXEC ?COMP ?ERROR !CSP PFA NFA
CFA LFA LATEST TRAVERSE -DUP MAX
MIN SPACE ROT > < = - C, , ALLOT HERE 2+ 1+
COLUMNS HLD R# CSP FLD
DPL BASE STATE CURRENT CONTEXT OFFSET SCR
OUT IN BLK VOC-LINK DP FENCE WARNING
WIDTH TIB R0 S0 +ORIGIN B/SCR B/BUF LIMIT FIRST
BL 3 2 1 0 USER VARIABLE
CONSTANT ; : C! ! C@ @ TOGGLE +! DUP SWAP
DROP OVER DMINUS MINUS D+ +
0< 0= R R> >R LEAVE ;S RP! SP! SP@ XOR OR
AND U/ U* CMOVE CR ?TERMINAL
KEY EMIT ENCLOSE (FIND) DIGIT I (DO) (+LOOP)
(LOOP) 0BRANCH BRANCH EXECUTE LIT OK
