Tempestas II, A Clock style Barometer
A Clock style barometer, that displays the current weather with different slides, driven by an arduino, 5 servos a PCA9685 and a bmp280.
A Clock style barometer, that displays the current weather with different slides, driven by an Arduino Nano, 5 servos a PCA9685 and a bmp280.
  • 1 × PCA9685
  • 1 × bmp280
  • 1 × Arduino Nano
  • 5 × Micro servo
  • Electronics
    SephenDeVos03/10/2020 at 07:35 0 comments
  • First tests
    SephenDeVos03/10/2020 at 07:16 0 comments
    First test of the actors
  • Stages
    SephenDeVos03/10/2020 at 07:04 0 comments
    The clouds, rain and lightning bolt (actors) are sliding between plates which I called stages to keep track of which actor slides between which stage. There are nine stages/plates the last one being the one to mount the electronics too.
    These are printed and CNC cut plexiglass sheets.
    The servos are mounted at different places. Every servo controls one actor.
View all 3 project logs
Rich text editor
Duncan wrote 03/19/2020 at 10:08 point
I love the theme, it's well done and very attractive.
rhainnecoles wrote 03/19/2020 at 02:48 point
beautiful barometer, dubbed Tempestas II, demands nothing of the viewer, but will likely command attention anyway because it looks so cool in https://floorrefinishingalbanyny.com/
Keith Hammond wrote 03/18/2020 at 16:56 point
So so nice!  Will you share files so that others can replicate it and extend it?  I'd love to see an IoT weather option ...
Mike Szczys wrote 03/16/2020 at 19:32 point
The stackup is so beautiful even when you don't add in the pop-up icons. Fantastic design work!
SephenDeVos wrote 03/17/2020 at 16:06 point
Thanks!
HarryTheB wrote 03/14/2020 at 11:12 point
Beautiful project. Might be interesting to optionally drive it from a weather feed.
SephenDeVos wrote 03/17/2020 at 16:07 point
Thanks!
Maakbaas wrote 03/14/2020 at 10:50 point
Very nicely done!
Thanks!
Dan Maloney wrote 03/11/2020 at 17:00 point
Love the look, and the whole concept is great. Wonder how it would look with Neopixels between the stages that could change color in relation to the temperature?
SephenDeVos wrote 03/17/2020 at 16:10 point
Thanks, With this material it would probably not work it's too translucent.
kmatch98 wrote 03/11/2020 at 15:45 point
Wow, this is really cool.  I like the 3-D effect.  Keep it up!
SephenDeVos wrote 03/17/2020 at 16:08 point
Thanks!
