Neoway M590 Undocumented Commands/ Features
Mobile data module capable of DNS FTP TCP/IP caller ID & more
Runs on 2G celluar network still available many regions.
Public Chat
When you're in the many countries where 2G is still supported (see ** link just below here) the Neoway M590 is dirt-cheap (around 1 USD or less) and in terms of bang-for-buck you just can't go wrong. This project is about finding what the M590 is capable of. What's for sure it can do way more than what it says in the manufacturer's documentation. Try out these fun undocumented commands in the FILE downloads section and see for yourself. Any unpublished command(s) you find you're welcome to post them here on this project's discussion.
General idea of what ELSE the M590 is capable cf
Loads of stuff that isn't known...
  • It can answer a voice-type call and send and receive DTMF tones through the connection.   It can see the incoming call's number before answering.
  •  It can go into low-power mode (while still online) to about 2.0 mA and be woken up using the DTR line or incoming call.  That's a LONG time running off a single LiPo cell.
  • Can do Internet DNS lookup of a domain name, uses the resulting IP address to connect to a FTP server and then sends or downloads files including viewing server directory contents.
  • Can operate as a dial-up modem over a voice channel (un-researched).
  • It can connect to a server with TCP ,  or in other words establish a live real time connection.
  • You can send to it a SMS containing configuration changes for your software to process.
  • And more...
FTP
Can read directories, read write files, change file names, append to files all sorts of things.
Data connection
TCP/IP connection to any IP4 address, such as a PHP server.  Use it for sending telemetry to a server.
Undocumented Commands = For Hacking
The M590 responds to many  factory undocumented commands with an "OK", or does something really cool.  Waiting to be discovered.  ~~~A full list of M590 commands (including the undocumented ones) appear in FILES download section~~~
Here's some examples
Example1:  Find out status info like battery charge level during a call
AT+CIND?
+CIND: 5,2,1,0,0,0,1,0,2,0,0,1
(Key to above raw data: :"battchg","signal","service","sounder","message","call","roam","smsful","gprs","callsetup","callheld","cellservices")
Or... Get unsolicited event-driven reports during a call.   Send AT+CMER: 2,0,0,2,0   and you'll get these updates.
Example2:   Get mobile network status
  • AT+CGED?      REALLY COOL
gives response  with detailed diagnostic info  GSM Service Cell,  PLMNs ,  receive and transmit levels, etc.
Example3:  Read Operator names
AT+COPN
+COPN: "360110","C&W"
+COPN: "42101","SabaFon"
+COPN: "42102","MTN"
+COPN: "22002","ProMonte"
+COPN: "22003","YUMTS, YUG03" ………
Generally speaking when hacking the commands take three main forms indicated by the last few characters.
  • ?    queries a setting or status
  • = <setting>   sets something
  • =?   quieries what's possible
Call 'Pranking'
Call the M590 number as a regular voice call.  The M590 says "RING" on its TXD port, plus the calling number (if you enabled it).   Send command ATH, call is rejected. Now you have a nice trigger for a software function without being charged for call. Such as reporting back operating status to the number that just called it.
HintsAndTipsUsingM590.rtf
Hints and tips for using the Neoway M590
msword - 4.94 kB - 03/28/2020 at 02:35
Download
FunM590Commands.txt
Some fun undocumented M590 commands to try out
plain - 236.00 bytes - 03/10/2020 at 22:15
Download
Data Link Transcript M590.txt
Transcript recorded while sending and receiving data over FTP and TCP
plain - 1.99 kB - 03/10/2020 at 21:45
Download
AT[plus]CGED-data.log
Data from M590 in response to undocumented command AT+CGED
log - 3.38 kB - 03/10/2020 at 20:50
Download
m590fullcommandlist.txt
Full list of commands recognised by M590
plain - 3.57 kB - 03/10/2020 at 20:47
Download
  • 1 × Neoway M590 + PCB (common on Ebay)
  • 1 × USB serial data interface
  • 1 × lithium battery
  • 1 × Computer
  • 1 × SIM card
  • 1
    Get started
    To get started, get some M590 modules. I remcommend getting several modules becuase sometimes a used module is less than perfect and may have poor signal quality or some other problem.    Build up the M590 PCB and connect to it a USB TTL serial data module set to 3.3V. Power the module off an 18650 cell.  Choose a nice Terminal program. I like to use Terminal v1.9b by Bray.
    Some tips:
    The M590 will most likely be trying to communicate with the last-used settings, 115 Kbs etc.  So one of the first things you ought to do is change the default bit rate to something easier to work with 9,600 bps.
    There's a lot of pages on the Net about getting up and running
  • 2
    Try out the module with a SMS (.... yawn...).
     You might need to try another module if it's not working too well.   Send a SMS (there's plenty of pages on the web about how).   You'll likely get bored quickly with SMS so now let's have some fun
  • 3
    Try the commands
    Look for the file on this page with the list of undocumented commands.
    A good one to start with is :
    AT+CGED
    Now call the number of the SIM card.
    You should get something like this:
    RING
    +CGEDService CellMCC:214, MNC:  7, LAC:0dae, CI:3107, BSIC:00,
    Equivalent PLMNs:
    MCC:214, MNC:  7
    Arfcn:00016, RxLevServ:020, RfChannels:000, ArÖ¹}‘•‘é068,
    RxLevFull:013, RxLevSub:029, RxQualFull:006, RxQualSub:000, GSM Ciphering:ON, GPRS Ciphering Algorithm: GEA0,
    ms_txpwr:005, rx_acc_min:255, cbq:ff, cba:ff, c2_valid:False, cr_offset:255,
    tmp_offset:255, penalty_t:ff, c1:-32768, c2:-32768, ch_type:02, ch_mode:0b,
    txpwr:006, dtx_used:False, drx_used:True, t3212:00255, acc:ffff, t_adv:004, bs_pa_mfrms:255,
    dsc:255, rll:032,
    amr_acs:0, amr_cod_ul:0 amr_cod_dl:2 amr_c_i:126,
    BEP GMSK: mean_bep_gmsk:255, cv_bep_gmsk:255, BEP 8PSK: mean_bep_8psk:255, cv_bep_8psk:255,
    Neighbour Cell 1:
    MCC: -1, MNC:255, LAC:ffff, CI:ffff, BSIC:0b, Arfcn:00014, RxLev:015C1_nc:32768, C2_nc:32768,
View all 3 instructions
Marcrbarker wrote 05/25/2025 at 14:50 point
May 2025  Update on Europe 2G. Still working and will stay on until 2033 to support all the devices still using it such as telecare and asset trackers etc..
I've just powered a 2G modem up a few minutes ago, checked the 2G signals and it's showing there's 5 cell owers connected to. So I sent a SMS, made a silent voice call, OK.   I then got an IP address over GPRS, and then through a url got a .txt file published on a www website. So that means dns is looking up names and resolving ip addresses ok.
Marcrbarker wrote 11/06/2024 at 09:55 point
2G switchoff debunk continues..  It's now last few weeks of 2024 and 2G still working in Europe. UK government announced support to 2030 possible extended, countries Belgium Spain Luxembourg for example similar story. Regular SIM card runs in a module costing a few cents which gives TCP IP connectivity.  And don't forget if want to try linking up with undocumented 2G around, you need 2G hardware!
Marcrbarker wrote 10/01/2024 at 23:28 point
October 2024 and this 2G module is still working fine in Europe!   It TCP connects to a web server http://, it does DNS lookups too, FTP uploads , even realtime telemetry in a StayAlive http session.
Ken Yap wrote 10/01/2024 at 23:44 point
Looks like you have until end 2025 for many European countries but a bit longer for some others: https://streetwave.co/mobile-networks/2g-switch-off-by-country-guide/ Enjoy it while it lasts.
Here, even 3G is gone.
Marcrbarker wrote 10/01/2024 at 23:59 point
I suspect 3G still available undocumented.  I just recalled this project is about discovering and publishing undocumented performance, so I guess that also means debunking switchoff reports. Still haven't finished rolling out utility smartmeters that use 2G.
By the way there's IoT on 2G with periodical global satellite coverage isn't there?  You'd need 2G hardware for that.
Ken Yap wrote 10/02/2024 at 00:11 point
I doubt it. It costs money for telcos to maintain 3G infrastructure, so there's disincentive to keep it going, even undocumented. Maybe there are still many utiity meters using 2G in Europe. Here things move faster because of a smaller population.
Marcrbarker wrote 03/26/2020 at 16:27 point
Also, don't forget 2G mobile network server satellites in orbit.  I sometimes see an extra 2G signal come and go, I guess there must be one that passes over here.
EDIT: I'm told there's a 'string' of them, not sure what that means. Of course to access 2G satellite one obviously needs these 2G-capable modems such as a m590
Marcrbarker wrote 03/26/2020 at 12:48 point
I can say 2G will be around a long time yet.  Even Stateside I expect there's millions of IoT non-human 2G subscribers out there.  Well speaking for The UK and Spain I reckon another decade at least.  A date of 2039 is estimated for England's electric utililies companies "Smart Meters" that rely on 2G. They won't even have finished completing the roll out of 2g-reliant smartmeters until 2024!!!
Ken Yap wrote 03/26/2020 at 14:30 point
2G might still be in use in some countries but can consumers get a SIM and service? The utility company might have private deals with the telcos so private experimenters won't be able to use the network.
Marcrbarker wrote 03/26/2020 at 16:04 point
I would imagine the 2G service will continue for some time but its availabilty won't be advertised. What to expect is telcos tech support staff officially stating "it no longer works" and sales saying "not available".   But then this project as its title says is all about finding out what's possible in the face of denial.
As far as I'm aware) the SIM card itself doesn't define 2G availabilty. Finding 2G is the modem radio hardware's job (the M590 is dualband 900 & 1800), and as I understand the SIM just supplies login creds.  (unless they can somehow block 2G access from the SIM)
If the SIM itself does block access to 2G (I don't think it does), one possible way round this could be get a SIM registered in a 2G-supported country and use it Roaming in another. If you're connecting with GPRS and only sending small amounts data the cost is surprisingly low and in some cases cheaper than a PAYG SIM bought in the target country.  While roaming receiving a SMS is free and so is receiving a caller's number via the M590's undocumented CLID capabilities.
Ken Yap wrote 03/26/2020 at 21:08 point
The point is the SIM is tied to the service you get so if they don't offer the service to you when you buy the SIM tough. Anyway it's moot, 2G has been switched off here.
Even 3G is scheduled for turn off here. The norm here is 4G and some carriers are offering 5G.
Marcrbarker wrote 03/27/2020 at 01:15 point
Apparently T-Mobile in northamerica seem to be supporting 2G until end of 2020.  https://www.slashgear.com/t-mobile-takes-a-swing-at-att-says-its-2g-network-will-stay-active-through-2020-14456049/    Also I see Sprint 2G shutdown date December 2021. I think the IoT Community [https://hackaday.io/search?term=IoT&tag=iot] will know much more about 2G availabilty in USA as there's millions of IoT devices in NAmerica still using 2G.
As for SIM cards I imagine there may be millions of live SIM cards still running that had been obtained some years ago running in hand-me-down used phones.
Well availability of 2G I don't think will be within the scope of this project, and I wish the best of luck to USA Hackerdayers tracking down 2G for their legacy IoT apps.
Ken Yap wrote 03/27/2020 at 02:47 point
That's nice for NA. Let us know if you find a cheap 3G or better still, 4G module. Fortunately I don't have anything that I need to monitor at a distance, just being a stickybeak.
Marcrbarker wrote 03/27/2020 at 03:27 point
Sorry to dissapoint you but you'll not find anything I publish in this project about 3/4G modules because this project is by definition a 2G module while it runs in the many regions of the world where it's still supported.
Ken Yap wrote 03/27/2020 at 03:39 point
Nah, I'm not looking to run anything over 2G or 3G/4G for that matter, just being a stickybeak as I said. So I am not disappoint  😉 .The 2G bands were reused here as the spectrum is valuable. Presumably the very few devices still relying on 2G were replaced with 3G versions. That should be good until 2024 when the largest carrier here will discontinue it, followed by the others at some yet to be announced dates.
By then we should be streaming HD onto our phones while hunkering down in our bunkers against pestilence. 🤔
I was quite impressed in 2017 in S Korea observing another bus passenger stream video onto his phone when we were on the highway seemingly in the middle of nowhere.
Starhawk wrote 03/26/2020 at 07:46 point
As far as I'm aware (per Wikipedia, in fact, so as far as *anyone* is aware) -- 2g is gone forever, *globally* (amateur, temporary just-for-a-hacker-con efforts, if there are any, notwithstanding) -- so unless this model of chip is at least 3g-capable, it's unfortunately essentially worthless and useless to anyone and everyone... :-/
I'd be interested in a cheap 4g job, though... especially super cheap. I stumbled over something on eBay recently that was essentially a universal 4gLTE mobile hotspot for tinkerers like us, minus battery and housing, but the listings all mysteriously disappeared at around the same time (late afternoon/early evening Eastern US time, 14 March), and I don't know why. All the sellers are claiming in broken English (it was import-from-CN/HK/TW *only*) that they're out of stock and I'm not sure I can believe that -- I had written one such seller a mere 7-1/2hrs earlier, and they'd had (reportedly) 30 in stock at that time.
Marcrbarker wrote 03/26/2020 at 16:31 point
Hi  Shame about Stateside.  Well I can say 2G is alive and well here in Europe I can say that definately and I do suspect true much of the world.  One day they will pull the plug here too but hey let's have some fun while we can using a 50 cent module packed with stuff that makes a microcontroller look like a 555!!
Starhawk wrote 03/27/2020 at 01:54 point
It's only a matter of time -- https://en.wikipedia.org/wiki/2G#Past_2G_networks
There's your timeline.
Any 3g/4g cheap modules, or info on them...?
Marcrbarker wrote 03/27/2020 at 03:04 point
Everything in life is only a matter of time :-)
Anyway, this project is about what the Neoway M590 2G module does that isn't published, in regions where 2G is still available.
Finding the cheapest 3G/4G would be a different project to this one. If there isn't one on Hackaday how about someone create a Finding The Cheapest 3G /4G Module project ??
Marcrbarker wrote 05/25/2025 at 15:00 point
May 2025 and in Europe 2G working fine. I've just also tried a 2G SIM800L it's very similar to M590.  With it made a voice call, then connected it to mobile internet and got an IP address, through a url got a .txt file published online. It resolves domain names to ip addresses ok. I understand 2G will stay on much of Europe until 2033
crun wrote 03/26/2020 at 00:32 point
Sadly 2G is now long gone here.
Any ideas on the cheapest 3G module?
