1Load SD card with proper OS
I used rasbarian but you can do whatever you want
2Put screen on Pi
My tft was very plug and play. Remember to add the heat sinks too.
3Properly place inside lunchbox
This was really the most important step. Make sure everything is lined up and where you want it. I used velcro so I could take out the parts that would need to be moved or charged. Only the Pi was mounted with double sided mounting tape.
4Insert wireless USB drive into Pi
This will connect it with the keyboard
5Connect battery to Pi
This turns it on and off
6Enjoy!
