I added PC Engine / TG16 support with version v0.16! Regular pad, 6 buttons pad, mouse & multitap up to 5 players are supported. Refer to wiki for cable schematic and config documentation.
My reverse engineering notes are available on the GitHub wiki.
PC engine and turbo grafx16 support video is here. This sharing means that we want to change all of the setup where we want to show you to must try this service and know how to fix this. Click on the play button and then you will easily see what we mention here.
