1Step 1
//Simple Stroboscope by Hari Wiguna byte ledPin = 13; // Digital Pin 13 byte potPin = 0; // Analog Pin 0 void setup() { pinMode(potPin, INPUT); pinMode(ledPin, OUTPUT); } void loop() { // This controls the frequency of the flashing, smaller delayValue = faster flash. int potValue = analogRead(potPin); int delayValue = potValue/4; digitalWrite(ledPin,HIGH); delay(2); // How long should the strobe be on. Larger is brighter, but will blur the effect. digitalWrite(ledPin,LOW); delay(delayValue); // How long should the strobe be off. }
