This is a hack (not a product) that customises FREKVENS to work with ProtoPixel’s software (Create) and hardware (WiFi Controller). The original presets are lost afterwards but you gain a lot of flexibility and new features. It does everything the ProtoPixel One Channel Controller can do, but in this case in a matrix that is the FREKVENS.
Features:
- create your own content
- load and stretch from ProtoPixel Create
- play content from the SD (internal)
- use webapp to load and select new content to the SD
- stream content from ProtoPixel Create
- emulate content on ProtoPixel Create
- generate an Access Point or connect to your wifi
I know this is years old, but I'd love to see some instructions on how you set this up.
