In a Mechanical Ventilator we need to be able to control and vary the pressure and the volume. In the pressure front Daren designed a pitot tube that takes a portion of the airflow that will be used to detect the pressure.
A project log for COSV - Cam Open Source Ventilator
Roller cam based portable BVM ventilator.
