Crowdsourcing finding a pressure sensor.
A project log for COSV - Cam Open Source Ventilator
Roller cam based portable BVM ventilator.
masterofnullMasterOfNull 03/24/2020 at 21:081 Comment
I need a differential pressure sensor.  Two to really do it right.
This one is perfect:  MPXV7002DP Transducer APM2.5 APM2.52 Differential Pressure Sensor
But, it won't get here for quite some time.
It occured to me that the automotive industry uses them.  Specifically I know they are used for EGR systems.  They may be used elsewhere as well.
If I had a part number, I could go down to the auto parts store and pick one up today.
I have other stuff to work on.  Anyone want to see if they can find a suitable sensor?
Filip Munz wrote 03/31/2020 at 11:39 point
