In a Mechanical Ventilator we need to be able to control and vary the pressure and the volume. In the pressure front Daren designed a pitot tube that takes a portion of the airflow that will be used to detect the pressure.
![](https://cdn.hackaday.io/images/2461241585079127373.png)
We are considering using some forms of electronic sensors or just using a U tube filled with a liquid to see the difference in an analogue way.
![](https://cdn.hackaday.io/images/9016851585079223777.png)
