Made a test jig for determining the proper setting for laser kerf.
You stick a bearing in the holes until it fits, and the number above that hole is your laser kerf. Similarly the slots below are for testing the edge joint kerf.
![](https://cdn.hackaday.io/images/9127801591739956227.jpg)
A project log for COSV - Cam Open Source Ventilator
Roller cam based portable BVM ventilator.
