Inputs
8 Binary input
8 Universal input
0-10 VDC (using the 10V jumper and ON jumper setting)
10 kΩ Thermistor (using the 10 kΩ Thermistor jumper and OFF jumper setting)
4-20 mA (using the 4-20mA jumper and ON jumper setting)
Outputs
8 Relay output (250VAC, 5A)
8 Analog output (0-10V)
Device Addressing
Set via DIP switches and jumper
Power
24VAC/DC
Technology
STM32F407VGT6 microcontroller featuring 32-bit ARM Cortex® -M4 with FPU core, 1-Mbyte Flash memory, 192-Kbyte RAM
Real-time clock
Connectors Module SPI, I2C, Ethernet
Communications Ports
2 RS-485 NET1, NET2 supporting:
BACnet MS/TP up to 76800 bps
Optional Modbus up to 115200 bps
Dimensions
18.8 x 10.7 cm
If you are interested can contact me via email daovanhoa12@gmail.com
ukmaker
