Hackaday.io Hackaday.io
Sign up Log in
VDP to TFT Converter
For afficionados of 80s home computers. Takes the output from a TMS9928 VDP and directly drives a TFT over parallel or SPI
ukmakerukmaker
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
84
0
0
0
Team (1)
  • ukmakerukmaker
Join this project's team
  • VDPtoTFT
completed project
hardware
VDP retrocomputing
This project was created on 01/07/2023 and last updated 3 years ago.
Description
This was a quick hack with a Nucleo board to see if I could sample the output from a TMS9928 and use it to drive a TFT using nothing but a cheap STM32 MCU.
Now I know it works, the question is what shall I do with it?
Details
Log In/Sign up to comment
Sign up with Github
OR
Board STM32f4, 2 RS-485, 8AI, 8BI, 8AO, 8BO
Project Owner Contributor
Main Board STM32
daovanhoa12daovanhoa12
The title says it all. This is a dual 12bit SPI 4-20mA output driver to be used to create analog outputs for current outputs.
Dual 12bit SPI 4-20mA Converter
wooddragon48wooddragon48
Hacking the Lenken373 HDMI over IP extender, building on the work done by Danman (https://danman.eu/blog)
Lenkeng373 Hacking
toru173toru173
What to do when you have a transistor output array from a vintage 80's stereo? Couple it to a driver board from Elliot Sound and crank it up
Amplifier using vintage output array
ron-stalmaRon Stalma
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "VDP to TFT Converter", please tell us the reason.
Send message
Remove Member
