Pandemic Ventilator for Prepper
Easy to build basic ventilator for breathing in response to COVID19
Public Chat
Pandemic Ventilator Project
Hi!
      New to site, lost previous description, building medical ventilator in response to COVID19 pandemic, hopefully it will not be needed (especially by me) however I am compelled to create a working unit that can maintain the required parameters of breathing function and contamination control STAT.
      I am attempting to keep it as simple as possible while maintaining the ability to modify or add features to the function on the fly. Relay logic , timers and fluid dynamics are what I am working with. As built is an adaptation of the designs to work with the actual stuff I have on hand. I will post pics and docs as I can publish them. Any feed back or helpful recommendations are welcome.
The control works, starting pneumatic circuit construction now. I will publish details as I go.
JPEG Image - 216.80 kB - 03/31/2020 at 18:10
Preview
PV1_A.pdf
Basic pneumatic scheme
Adobe Portable Document Format - 1.01 MB - 03/24/2020 at 18:01
Preview
  • Pressure Monitor
    flanagan • 04/10/2020 at 18:02 • 0 comments
  • Pressure/Flow mangement
    flanagan • 04/10/2020 at 13:43 • 0 comments
    I have sourced a gas pressure sensing unit that can accurately measure air pressure and read down to gauge pressure ( - 1 bar) vacuum, It has two nc/no relays and an analog output for PID, with programmable operating parameters, this can be easily integrated  into my current design and control circuit and can provide a visible display, and alarm supervision. The price was very reasonable for a unit like this, but as you are all aware it doesn't take long for those expenditures to add up. Depending upon configuration I think I may be able to monitor pressure and flow direction by using two of these units at different locations in the pneumatic scheme.
    Progressing well.
  • Valve spec change
    flanagan • 04/08/2020 at 13:44 • 0 comments
    Started with 1/4 " aluminum body solenoid valves, primary side of circuit they are fine, output side volume is on the low side, found some reasonably priced 1/2' plastic body valves, going to continue with testing with what I have(for control evaluation) until new valves arrive, I think the plastic valves will be better suited to wash down and decontamination , which is a primary concern. I am maintaining separation of the control and pneumatic arrangements to facilitate cleaning and servicing without exposing the control to inadvertent contamination.
  • Basic control operation
    flanagan • 04/04/2020 at 21:25 • 0 comments
    I just powered up the control. It functions as planned. Hooray!
    Construction of the pneumatic segment of the unit begins today.I will assemble on a bench to confirm operation prior to final assembly in cabinet. I will provide pics and vids, once operational I will update electrical and pneumatic schemes to reflect as built revisions. Instrumentation will be the next challenge, current design utilizes gauges and timers. bi-directional airflow monitoring capability is the target, for function and monitoring.
View all 4 project logs
