Pressure Monitor
04/10/2020 at 18:02 • 0 comments -
Pressure/Flow mangement
04/10/2020 at 13:43 • 0 commentsI have sourced a gas pressure sensing unit that can accurately measure air pressure and read down to gauge pressure ( - 1 bar) vacuum, It has two nc/no relays and an analog output for PID, with programmable operating parameters, this can be easily integrated into my current design and control circuit and can provide a visible display, and alarm supervision. The price was very reasonable for a unit like this, but as you are all aware it doesn't take long for those expenditures to add up. Depending upon configuration I think I may be able to monitor pressure and flow direction by using two of these units at different locations in the pneumatic scheme.
Progressing well.
Valve spec change
04/08/2020 at 13:44 • 0 commentsStarted with 1/4 " aluminum body solenoid valves, primary side of circuit they are fine, output side volume is on the low side, found some reasonably priced 1/2' plastic body valves, going to continue with testing with what I have(for control evaluation) until new valves arrive, I think the plastic valves will be better suited to wash down and decontamination , which is a primary concern. I am maintaining separation of the control and pneumatic arrangements to facilitate cleaning and servicing without exposing the control to inadvertent contamination.
Basic control operation
04/04/2020 at 21:25 • 0 commentsI just powered up the control. It functions as planned. Hooray!
Construction of the pneumatic segment of the unit begins today.I will assemble on a bench to confirm operation prior to final assembly in cabinet. I will provide pics and vids, once operational I will update electrical and pneumatic schemes to reflect as built revisions. Instrumentation will be the next challenge, current design utilizes gauges and timers. bi-directional airflow monitoring capability is the target, for function and monitoring.
