I've included A4 and US-letter versions. Completion of this project probably requires either a laser or inkjet printer.
I don't intend for this to replace any of the high quality options that are out there, both from the maker community as well as commercial outfits. Instead, this is really aimed at the outposts or those truly hit hard with a serious outbreak. Basically, anywhere that the need urgently outstrips the availability of all other options.
The design is inspired by origami. There are only two folds here, mountain and valley. For more info, check this link:
http://www.origami-instructions.com/origami-valley-and-mountain-folds.html
Instructions:
If you DO have a 3d printer:
- Print the front and back STL files of the jig. it is for US-Letter size, NOT yet ready for A4. I'll update ASAP.
- Place the plastic sheet between the front and back parts of the jig. the points on the back part of the jig should line up with the holes on the front side of the jig. Make sure the plastic sheet is aligned straight and all the way into the corners of the jig.
- Use a ball-point pen to firmly crease the plastic sheet on both sides against the curves provided.
- Cut or punch out the holes at the locations where dimples have been made on the sides of the shield.
- Using the creases you made earlier, make the creases much more sharply defined with your fingers. Don't forget that one must be a mountain fold, and the other must be a valley fold.
If you DO NOT have a 3d printer, but DO have a laser printer and can print directly to your plastic sheets:
- Print the PDF file for your plastic size directly onto the plastic sheet
- Place the plastic sheet on a wooden or soft plastic surface
- Using a wheel-style pizza cutter, a very dull knife, or a strong pen: trace firmly over the fold lines indicated, the valley fold on the front side of the plastic.
- Flip the plastic over and firmly trace the mountain fold on the reverse side of the plastic
- Cut or punch out the holes at the locations indicated on the sides of the shield.
If you DO NOT have a 3d printer, but DO have an inkjet printer and can NOT print directly to your plastic sheets:
- Print the PDF file for your plastic size directly onto a piece of paper the same size as your plastic sheets
- Place the plastic sheet on a wooden or soft plastic surface, on top of the printed guide. Try to keep the corners of the guide and the plastic sheet aligned as much as you can.
- Flip the plastic over but keep the guide in place and firmly trace the mountain fold on the reverse side of the plastic
Now that your shield is folded, insert rubber bands, string, or yarn through the holes and make a strap or cord that should fit around the head above the ears. Adjust this strap so that the shield stays in place but doesn't cause too much pressure.
Take a look at the images to see how it fits. Some of the pictures are made with paper so that you can see how it fits more easily. The transparent sheet is a bit hard to see with my camera.
If you want to make a modification of the jig for yourself, it is on Onshape here:
https://cad.onshape.com/documents/12d110feb107370d673a9583/w/92846e0cb4d7b9a24707e92b/e/35c0bab7e83ee05a4f8d79a3
I truly hope this helps you, your communities, and any fellow humans to overcome a potential obstacle in our journey through challenging times. Please share and pass this on to any who need it or are interested....
Dustin Sysko
Federico Virdia
Yusuke Tanaka
The folded medical facial shield is a practical and efficient solution for personal protective equipment, requiring no 3D printing, which makes it accessible for rapid deployment in various settings, such as healthcare facilities and community events. This innovative design is lightweight, easy to assemble, and offers reliable coverage, ensuring that frontline workers and individuals alike are protected from airborne particles and droplets. Just like the excitement and strategy found in the Tekken 7 APK download, where players can dive into intense battles with a variety of characters, the folded medical facial shield represents a proactive approach to safety, empowering everyone to engage in their activities with confidence and peace of mind.
