Two threadless leadscrews with opposite "thread" directions. Brushless motor control of the drives. Linear and rotational magnetic encoders.
drive_mini.MOVquicktime - 2.51 MB - 03/26/2020 at 16:44 |
Read ADC
aa1 = ADC_SAR_GetResult16(0u);
bb1 = ADC_SAR_GetResult16(1u);
cc1 = ADC_SAR_GetResult16(2u);
dd1 = ADC_SAR_GetResult16(3u);
Do CORDIC Calculation
int cordic(int32 aa, int32 bb, int32 cc, int32 dd)
int hor, ver;
hor = aa - cc;
ver = bb - dd;
double abs_val_sq = (hor * hor) + (ver * ver);
double inv_amp = 1.0 / (sqrt(abs_val_sq));
double hor_f = ((double)hor) * inv_amp;
double ver_f = ((double)ver) * inv_amp;
double hor_s = asin(hor_f);
double ver_s = acos(ver_f);
double ang_r = 0.0;
double ang = 0.0;
int ang_cordic=0;
if (hor_s>0)
if (ver_s > pid2)
ang_r = ver_s + (pi-hor_s);
else
ang_r = ver_s + hor_s;
else
if (ver_s > pid2)
ang_r = pi + (pi - ver_s) + (pi - hor_s);
else
ang_r = pi + pi + (pi - ver_s) + (pi + hor_s);
ang = ang_r * rad_deg;
if (abs_val_sq > 100000) // good (Todo crc or party)
ang_cordic = (int)(ang_r * rad_12); // | 0x8000;
else // bad
ang_cordic = ((int)(ang_r * rad_12));
return (ang_cordic);
This innovative design for controlling the player on the shaft in a robotic table soccer system is quite impressive. It addresses the challenge of achieving both linear and rotational movement efficiently. The use of custom components like the PSOC4 brushless controller, magnetic rotation absolute encoder, and multi-pole magnetic linear encoder demonstrates a high level of engineering sophistication.
What's particularly interesting is how the drives are incorporated into the sides of the table, leaving the shaft's ends free. This approach not only saves space but also allows for a more seamless and immersive gameplay experience.
you can also see my work for soccer https://socceriate.com/soccer-players-with-number-11/
