1Assembling the hardware
Solder the pins to the breakout board of the thermal sensor. Connect the 5 pins of the thermal sensor to the first 5 pins of the GPIO on the Raspberry Pi:
- 5V -> pin 1
- SDA -> pin 3
- SCL -> pin 5
- INT -> pin 7
- GND -> pin 9
Screw the display to the Raspberry Pi and connect the HDMI ports with the bridge plug that came with the display.
Create a nice case to hold everything in place :)
2Installing the software
The software has been written en tested on Raspbian Buster.
Go to the GitHub page and follow the instructions in the README file. It gives a detailed description on how to compile and install the software.
Gilbert François
