Yes, that should be interesting. My guess is that it is slower than the PMBT2369, because it is not optimized for saturation switching. See also my results for the HF-transistor.
Yes I remember these but I also remember seeing in the datasheets that these types of transistors are optimised for switching at a given current point. That's why your last curves "ring a bell" :-)
Yes, indeed. I guess the high supply voltage in the CDC6600 was also chosen to be less susceptible to droop. If you have a more stable power supply it should be possible to reduce supply.
Actually it's crazy, basically all of the headroom beyond the logical high level (1.2V) is burned as waste energy in the resistors. Thats (6V-1.2V)*10mA/2= 24mW per gate! Only 6mW are actually needed for the switching.
I should make a similar measurement with the BFS480 :-D
10mA is quite a lot...
But overall power could be reduced by using lower power supply voltages. Maybe even use a standard 3.3V PSU ? Rc=470 would then be the sweet spot :-)
Fortunately today we have PoL regulators :-)
