Designed to be laser cut out of 0.4mm-0.6mm PET Sheet or similar material. Attachment to rubber strap uses a simple pinching mechanism. See video for instructions.
This face shield design is not endorsed by or approved by any healthcare institution or regulatory body and should only be used as reference and for personal use, at your own risk.
I see a lot of criticism floating around of masks that aren't closed above the eyes. You might want to move the mount down a bit, so you get more protection up there. Weird times we live in.
